1 - 3 of 3 Posts
I have ended up with 2 powerglides. One is a forward valve body and the other is a reverse valve body. Both have t-brakes and stock cases. Which one is better as far as strength?
The internal hard parts will be what determines which is stronger..
Take them apart, unless you have the build specs on them...otherwise we are ASSuming......
1 - 3 of 3 Posts
