1 - 1 of 1 Posts
I have to make the decision which kind of lifter to use:
The lobe lift will be over .580" the valve lift will be 1.100"
The came core will be 65mm
Spring pressure will be around 400/1100 lbs...
Up to now I was using Jesel DLC coated only, because of their superior quality and close tolerances.
The possibilities are (all .850 wheel ):
1. JESEL .937 keyway lifter
2. XCELDYNE. 937 keyway lifter
3. Cam FX 1.062 keyway lifter View attachment 55425
Thx in advance
MeXX
Either will work. We have used a lot of Jesel with zero issues. Xceldyne has lifters in 40% of the NASCAR Cup cars so it's proven at least in that arena.
1 - 1 of 1 Posts
