1 - 5 of 5 Posts
Ok guys, getting ready to build myself a rear at the end of the month and want to start gathering parts. It will either be an 8.8 center section w 31 spline locker, moser axles, 4.10's, etc with my 10 bolt axle tubes welded on, backbraced, and a custom tq arm mount built.
Or, I'll be doing the same thing with a 12 bolt.
What are parts cheaper for and what will be strongest when mildly built like this?
It's in a stick car with no more than 500hp at the tire right now. Looking for 60's in the 1.5 range. I dont sidestep the clutch and shock the drive train when I launch though. I lock the line lock and put a little pressure on the drivetrain and slide the clutch out.
Either one will work fine for what you are doing. 8.8's are usually more available and cheaper to buy as far as castings go. Even a well built 8.5 10 bolt will work fine. What kind of car?
94 Camaro. I know of an 8.5 10 bolt going 1.2-1.3 60's in a badass nova and loving it. (Ultimate346 on here) I've thought about that option too. I guess it boils down to what housing I can find the cheapest / easiest and I'll start going from there. What's a good ls unit for 8.8's or 12 bolts? I'd like to find a tru trac but they seem pricy. Will an Eaton or stock clutch type ls unit hold up to being beat on fairly well?
I kill parts
I'm not a fan of a 12-bolt with a tq arm in a clutch car. We've had several people locally kill them repeatedly in clutch cars, the auto cars on the other hand tend to do very well with them.
Personally, I don't change the axle tubes, just the brackets. Much less work, same end result.
1 - 5 of 5 Posts
