1 - 14 of 14 Posts
What head gasket would you guys recomend for this combo?
388ci SBC
3970010 Block
4.060 bore
3.75" stroke
11cc domes
Dart Aluminum Pro 1 230cc
~13.5 to 1
No spray, all motor
Thanks,
Frank
the standard felpro with with a steel ring can dig into the aluminum, the cometics are the best but have been TOLD you need to start with fresh surface on both sides to use them.
cometic
Felpro 1003
curious-why such a big runner i have the exact same setup with iron eagle 230s and 11-1 and always thought it would run best with spray? vs swapping to 200cc, na
Discussion Starter #10
Thanks for the info guys. Last season I used the Felpro MLS and didn't see any advantage for the added cost. When I ran this combo years ago I used the Felpro 1003 and never had any issues so I am going to try them again.
Frank
Discussion Starter #11
If you are asking why I picked the larger runner head I bought them close to 10 years ago and don't remember why? :confused: Actually someone recomended them to me.
It ran okay last season. 10.10 @ 135 with a junk converter. Just picked up the heads from MotorCity Motorsports from getting freshend. Hoping to see some 9sec time slips this year.
Frank
Felpro MLS should work good with a aluminum head. I had one on my iron head, and always had coolant seapage
1 - 14 of 14 Posts
