Was finally able to get out to the track last weekend and start to really try tuning the car on the nitrous. A little about the combo
3470lb Mopar A-body
4**ci small block, 10.25:1 compression, aluminum heads, old school solid roller, locked timing, 94 octane pump gas motor (same fuel pump and fuel feeding motor and nitrous)
904 three speed
Caltracs, monoleafs, D/A shocks, 275 pro tire with a 4.10 gear out back
Cheater plate kit
Made a couple of passes on the motor just to check for repeatability and see if N/A performance changed with getting the converter tightened (Tighter converter netted slower e/t's but also less mph...not sure if that is how it is supposed to work still since MPH I thought was to indicate HP?). Went 11.12-11.13 at 120mph.
Now for the nitrous passes. All passes were made with the bottle pressure at 950psi leaving the line, and off a transbrake. Jetting in the plate is .063N/.055F. Pulling all the timing out at the hit with a Mallory hyfire 6 box (Cannot ramp anything back in) and running NGK 9 plugs (8's on motor) with .025" gap in them...no other electronics
1st pass
12 degrees of timing pulled (From 34 to 22 total), 5.5 psi flowing fuel pressure
Launch at 3000rpm (although car left somewhat sluggish, I think I didn't have the pedal matted on the brake), shift at 6700rpm
60ft-1.57, 1/4 e/t- 10.58, 1/4 mph-126.72
2nd pass
I added 1/2lb of fuel pressure (6 psi flowing), everything else staying the same (actually had the pedal matted).
60ft- 1.59, 1/8 ET-6.82, 1/8 MPH-102.5, 1/4 ET-10.64, 1/4 MPH- 126.10
3rd Pass
Left everything the same, except I only pulled 10 degrees of timing (total of 24) in hopes that it might pick up some mph with the added fuel pressure as the timing mark looked low on the bend of the plug. Also tried some shock adjustments
60ft- 1.59, 1/8 ET-6.87, 1/8 MPH-101.06, 1/4 ET-10.77, 1/4 MPH-123.95
4th pass
Seeing that the car slowed down, I tried pulling a little more timing then what my first passes were like- 13 degrees pulled, for 21 degrees total, with the same 6psi flowing fuel pressure as the last pass. Again tried more shock adjustments (All passes were spinning BIG TIME...but this would be my last pass since afterwards a bad shock had me packing up).
60ft- 1.69, 1/8 ET-6.98, 1/8 MPH 102.05, 1/4 ET- 10.83, 1/4 MPH-125.36
After all of this I know I need to work on my suspension...Big time! Car is just spinning like crazy. Also, it seems like once I get above 6800rpm the car starts to break up. It is not fuel related as my fuel pressure gauge is rock solid all the way down the track at 6.5lbs. I am thinking it might be a valve spring issue, but not sure how much that is leaving on the table, and I am not going to make any full passes until that is sorted out.
As for the tune up. I was pulling the plugs (fresh ones) after every pass. I am no expert, and was basically just trying to read for detonation, the timing mark, and the base fuel ring. I tried the safest ways I could to make changes, but not sure I even went in the right direction at all. I found it a little strange that on such a small hit the car ran better with 12 degrees pulled then with 10 degrees pulled, even when I added fuel to try and be safer. I know it is pump gas, but 12 degrees on a 150 hit seems like a lot...do i need even less fuel jet in the plate or less fuel pressure? Looks like my first pass was my fastest.
Any insight as to what I may be missing here, things to try? This was my first time actually really getting a chance to spray the car more then 1 pass and make a couple of adjustments along the way to see what would change. I would eventually like to see a bottom 10/high 9 out of the car if possible with a little more jet.
3470lb Mopar A-body
904 three speed
Cheater plate kit
1st pass
2nd pass
3rd Pass
4th pass
