1 - 6 of 6 Posts
I have a current combo in my street car which is a AFR 210 headed 381 CI SBC with 9.2-1 comp ratio. Has a cammotion roller with 262/252 .630 lift on a 116 CL. The engine currently is running twin gt35r turbo's I am thinking of going to a single gt4788 turbo, as I want to put this combo in my drag car which has a hurt engine.
I already have the gt4788 t6 turbo with a .96 ar ex my delima is that I want the car to run in the sevens with the small block what should I do. The car weighs 3200 with a sbc and the 60 foot is usually high 1.20's .
Do you think that I cam get into the seven's with the single, or will the twins be better.
I am too spoiled from being in the seven's with the other combo I had before with a 106mm but I think it is just too big for the 381 what do you think?
Thanks in advance!
I'd put a PT91 or PT98 on there and be done. That should go pretty easily into the 7's on that combo.
- Brian
1 - 6 of 6 Posts
