One of my 990 rectangle ports cracked. I was thinking of trying a set of 781 or 049 oval ports. Most people seemed to think they would be a major restriction without alot of porting($$$). Here are two options I'm looking at.
#1 Brodix Race Rite -2plus(312cc) heads bare and use all the parts from the 990 heads.
#2 I found a set of Brodix -2X(340cc) heads NIB made around 1998.
Compression would be upped to 13.3:1 and race weight would drop to 3200 lbs. by using the aluminum heads. I don't mind spinning the motor to 7500 if it's required. The car is drag only, running 1/8 mile. Here are the details with the 990 heads. Let's hear your thoughts.
BB Chevy 4.375 bore x 4.000 stroke 481cid
12.25:1 CR
6.135 rods
39* timing locked out
-7 NGK std tip plugs
GM iron rect port '990' heads with 2.25/1.88 11/32" stem valves
bowls blended, short side radius reworked, and chambers unshrouded
Manley Nextek springs #221424 1.640 OD & 250 lbs seat w/ tit. retainers
Head flow @ .700 lift INT 353 Good/323 Bad EX 218 w/ pipe
Howards solid roller 7/4 swap cam
ADV 314/322
050 278/287
200 187/196
110 LSA/109 int CL
lobe lift .439/.430
valve lift .790/.731
rockers 1.8Int/1.7Ex
Edelbrock Victor 454R gasket matched & ported plenum
1" open spacer & 1/2" blended 4 hole super sucker style spacer
1050cfm 2-circuit dominator E-85 carb by Mark Sullens
Hooker super comp headers for G-body
2" x 30" primary
3.5" x 10" collector w/ 12" collector extension
The engine is in a 84 Regal that weighs 3300 lbs w/ driver. It has stock style bolt on suspension and 29.5" x 10.5" slicks. Trans is a PG w/ 9" spragless converter. I leave off the transbrake @ 4500 and shift @ 7200. Converter flashes 5600 at launch and falls to 6000 on the gear change. Rear is a 9" w/ 4.86 gear. It goes thru the traps @ 6600.
The best pass to date has been:
60'......1.359(4.33) & 1.328(4.86)
330'....4.029
1/8.....6.302/107.56
This pass was made in cool fall air @ night w/ 4.33 gears.
12.25:1 CR
6.135 rods
ADV 314/322
050 278/287
200 187/196
110 LSA/109 int CL
lobe lift .439/.430
2" x 30" primary
330'....4.029
