1 - 10 of 10 Posts
Mr. Noisy
ok, i have just been talking to a mate of mine and was hoping that you lot might be able to help.
he is wanting to know where he can get his oil feed from with a motown block.
is there an oil gallery at the front of the block that he can drill and tap? or does he have to use pressure gauge feed at the rear of the block?
thanks in advance, justin.
Custom Engine Shop
Either will work!
Mr. Noisy
do you know where he can find the front gallery? there are no plugs or bungs at the front.
he would preffer to get the feed from the front of the block if possible.
thanks for the quick response robert. :)
Custom Engine Shop
Justin, sorry missed the part theat you don't have the front drilled.
Yes you can drill it or just run a longer line. Depends on how much work you want.
We put a manifold on the motor to feed the gauges, sensors, turbo, etc...
Custom Engine Shop
1 - 10 of 10 Posts
