1 - 20 of 22 Posts
· Registered
I have all the parts less bearings and the yoke.. no driveshaft yet so I'm open to size as far as universal. I'm just wondering if it's worth the trouble, or should i find a set of 4:10s that have the standard 29 spline pinion...(would still need yoke, but at least it would fit different gear sets...)
it's always something ya' know..
mike
· Registered
Discussion Starter · #17 ·
I don't know what measurements you need.. don't have the yoke. I could measure the spline on the pinion
This is the one lised on ebay...any ideas if this is for a dana 60??
Dana Spicer End Yoke with 10 splined hole
1350 series to be use with kit 5-178X or 5-799X U-Joints
Major dia. = 1.500"
Ground Hub dia. = 2.250"
Lenght thru hole = 2.000"
Centerline to end = 3.500"
Joint angle = 22.0
Style = BS
1 - 20 of 22 Posts
