1 - 12 of 12 Posts
Where is the best/cheapest place to buy a drum of E85 in the Detroit area? Specifically I'm in Waterford (up towards Pontiac) if that helps...
I am going to dyno at the end of November, and I know I can't just get "E70" out of the pump to dyno/tune with...
No I haven't done anything. I just know that it's going to be more towards E70 by the end of november then E85. I was just looking to buy a drum for consistancy in the tuneup to race with, then drop the boost and run out of the pump fuel on the street. I just don't have the time to get a drum and go fill it up right now, and it's starting to get cold around here already so I'm guessing it's already not E85.
huh? Go to the gas station. Buy a gallon, test it to see its ethanol %.....
Down here they sell e85 year round, I guess its different in northern states?
Discussion Starter · #7 ·
Sorry I just assumed that everyone knew that. In the winter, the 85% eth. doesn't start well in the cold. So they blend it down as far as 70%. That's why I was just hoping I could buy a pure 85% 55gal drum and not worry about it.
I bought e85 right out of the pump at the Sunoco station on the corner of Woodward and Square Lake rds. about a month ago and it tested at Ninety-5%.:rolleyes: I bought a drum of E98 from Fairgrove oil early last year so I could "sweeten" up some E85 that tested at 74% for a dyno session. Get an alcohol content tester, a drum of E98 and blend your own.;)
http://www.fairgroveoil.com/e98.html
Discussion Starter · #12 · (Edited)
I have a tester, I just wanted to buy a sealed drum of it. I just figured it would be easier then finding an empty drum, testing the fuel myself and filling it up. I have to have the car on the dyno in 8 weeks and the motor hadn't even assembled yet...
1 - 12 of 12 Posts
