1 - 10 of 10 Posts
I put in a new set 3 months ago. I have about 150 logs on them and the motor is starting to misfire which means the gaps have opened up. I'm using an Autolite 3923 at the 750-775 hp level..
Misfires are caused by a lot more than gaps opening up. If you have a good ignition that is less of an issue than other things. Too cold of a plug can foul even with proper tune. Can glaze by not burning off deposits. That will cause a misfire. Many other things besides gaps.
I had misfiring over the winter.. Put the new plugs in there and it came back to life. But I have about 1300 miles on these with various power levels of street pulls as I tweek the tune and it's starting to break up again.
My wires might need replacing tho because I don't get the nice clip feel when I push them over the ends of the plugs.
But you like the 3923's at this level?
Colder plug would most likely make it worse. Plug porcelain is probably getting glazed. Just install fresh plugs.
I'ma yank those plugs for inspection.. I gapped them at .020. I'll see how how they opened up. If they opened up a lot which I think they did, then I'll try a 3922
Is this a sbc?
Sounds like you have a much higher estimate of plugs than i do. Especially while tuneing ive always heard change them often. As soon as you think the tune is good, new set. On motorcycles i change my iridiums every 10k amd thats stock engine, ignition, exhaist intake and a tune. And surely mileage and power go up.
1 - 10 of 10 Posts
