1 - 8 of 8 Posts
Is there any difference in wheel alignment from a street/strip car with skinnies to a normal everyday vehicle?
We run more caster as well. For a street deal we will normally run 2-3* of caster, .5-1* on the camber. Race stuff will be 6-8 on the caster, 0 or .1 on the camber depending on what it does throughout the travel.
For a street/strip vehicle, go with the stock specs. It is always a good idea to place some weights, equal to your body weight in the drivers seat during the alignment procedure.
For a race only vehicle, more caster is recommended as well as checking and correcting any bump-steer. Correcting bump steer can be a major project, however the results are very worth while.
Some people go the extra mile for a drag only setup and jack up/raise the front end to simulate weight transfer and the car's stance going down track.
This is how mine was always done.
1 - 8 of 8 Posts
