1 - 14 of 14 Posts
The X-Bomb
i got a new cowl hood for my car and the only way is to pin on. so what works best and fast so you dont have to screw with undoing 10 dzus clips? but i dont want any cheap mr gasket hood pins sticking thru the hood either
it really sucks they only come in pin on.
The X-Bomb
Discussion Starter · #4 ·
i didnt know if there was any other trick ways of doing this....looks like duct tape it is! i really dont think the glue would bond metal to fiberglass but hey sounds like you know what your doing so maybe.
Brewmaster
The really good stuff holds till 135, beyond that the adhesive can't hold on it's own. 135+ and you need to use a staple gun to hold the velcro strips on :rolleyes:
Ive just used 4 hood pins in the past. Worked fine.
4 hood pins will work to a certain extent, but any i've seen that use that don't seem to fit all that well. use the dzeus fasteners. yeah, it's a pain in the butt to get them off, but you'll be happier with the fit. they make dzeus fasteners that use an allen head to turn them. alot easier!
1 - 14 of 14 Posts
