1 - 11 of 11 Posts
changing trans to reverse pattern, need a new shifter. i have hurst quarter stick and has welded in gate plate cant change it.
I use Turbo Action along with a CO2. I like the gated shifter VS the ratchet type.
Jeff
this is what I have and love it. Anyone else that has been in my car loves it also. I don't really care for B&M products but they did make this one right.
that sucks the cover used to be a carbon fiber composite material instead of aluminum on the stealth shifter. :smt013
Precision Performance or Turbo Action, can't go wrong with ether one.
Banned
Winters! Very easy to change the shift plate should you go from one type of trans to another. Been using mine for 20 years, changed the plate a few times (started to wear-out the aluminum), swapped the plate from a 3spd to a 2spd. Never, ever had a problem with it.
Turbo Action is a very similar shifter but the knob is a pain in the ass to take off and put back on if you need to change the plate. They use a roll pin to attach the knob, the knob on the Winters shifter screws-on.
1 - 11 of 11 Posts
