1 - 2 of 2 Posts
I have mark williams large bearing case, currently has 28 spline pinion. here is what i think i need: new 35 spline yoke, Large pinion support, gears :), shim kit seal. did i miss anything? will a strange pinon support be ok with a MW center? I would think they would all be the same but just want to be sure. any buddy have a particular install kit they like?
Gears, Yoke, Support, Bearings/Races, Seal, Solid Spacer or Crush Sleeve, and Pinion Nut. All of the 5-bolt supports are the same and will inter-change with each other. We can help you with everything that you need if you are interested.
1 - 2 of 2 Posts
