1 - 19 of 19 Posts
Intake gasket sucking in from the lifter valley go look close at that side intake gasket....
Check and see if rocker stud holes go into intake port. if so they need to be siliconed or they will suck oil past studs.
im not to shure about the intake definatly possible it dont look oily plus its all 4 witch is leading me away from the intake . did it idol alot maybe hes got the idol mixture screws all jacked up after all its a dual plain intake super ritch right bank and an ok left carb issue ? you have a fiew good ideas where to look
i had a customer with one of those carbs did the exact same thing turned out the carb was the problem holley sent us a new set of metering blocks because they had a problem with some of the ones they sold.
wasnt a pefect fix but it was better and we were able to tune most of it out,later on switched to a proform 750 and the problem was gone.
pist'n Broke
bingo,that was my problem.but when i changed mine i also up graded my ingnition.
so im not 100% sure. maybe if have access to other part's laying around to try
1 - 19 of 19 Posts
