1 - 3 of 3 Posts
I have a Rodeck 350+ raised deck, std cam,std pan block. The deck is +.290.It
is in great shape.It has some repair work to #2 and #4 main web.repair work was professionally done. Its a dry sump block with a Peterson 4 stage pump and tank.
I also have a new set of AFR 227 heads. with 1.75 and 1.6 Comp Stainless rockers
Isky RR-660 solid roller.
Iam trying to come up with what size of motor I should build .
The car is a tube chassis 64 Nova. Drag race only.Thinking of a 427 or 445
Any thoughts ?
3.650 or 3.750 stroke max is my suggestion. The standard cam size and location is a killer:(. Kind of a waist in even using the taller deck.
1 - 3 of 3 Posts
