1 - 8 of 8 Posts
I have a New set of 8 Xceldyne Titanium intake valves 2.100 with 5/16 stems by 5.640 long. I know will fit Yates.. But what else will they work in?
Hope to help someone out that could used them!
Thanks!
Discussion Starter · #2 ·
Anyone ever have them cut down? I got these planning to cut them down to a 2.08 but didn't work out on the length.. Hoping someone could make good use of them.
Yes they can be cut down. Shorter in length and in diameter . If the length is to be cut you would need to run a lash cap as the hardened tip would be cut off .
It is not to bad of a job to do either just a little time and machining which is nice to do.
Discussion Starter · #4 ·
Can you not put a hardened tip back on them?
Thanks..
Well i assume they could be put back in if you can find a supplier for them .
I just think it would be less complicated to just use lash caps as you would have to machine a hole in the end of the valve for the tips to press into.
Would these be worth $400.00? If so would love to sale them.
Discussion Starter · #7 ·
Would like to help someone out.. If they can use these?
Discussion Starter · #8 ·
Could you use these?
1 - 8 of 8 Posts
