1 - 8 of 8 Posts
what will make more power with a s480 turbo, a 350 ci, 383 ci or a 400ci sbc. taking in the turbo size and amount of boost . thanks for the help.
Custom Engine Shop
Depends. The 80 will only support so much hp, as any other turbo.
Some combo will bee more efficient than others, Cam, Heads, Rpm blah, blah blah...
So if it supports 1100-1200hp it wont matter what size the engine is?
basically, but you want the combo that produces that with the compressor map being at the most efficient area.
I would say a 355 would most likely be better than a 383 or 400 if your looking to make full use of the 80. Any larger and you end up in a spot on the compressor map where you might not use the turbo to all its potential.
That is what I wanted to know. thanks.
1 - 8 of 8 Posts
