Here's the combo, what do you think? I know the downfalls in the combo for what I want to do with it, but as it sits, what do you guys predict?
360 smallblock chrysler stock stroke .030" over KB pistons
IMM prepped RHS iron heads flow peaks 271 at 550" on the int, 190 at 550" exh
Bullet hydraulic roller cam 243/251 at .50 duration, lift is 562/562 on a 109 LSA with 4 degrees advance ground in on a 1.5 rocker (not sure if i should step up to the 1.6 and getting 600/600 out of it). Exh lobe is considering light nitrous use in the future as well
Was told rpm range would be 1500-6200, but possibly higher?
Edelbrock RPM air gap port matched with a Holley 750HP on top
1-5/8" headers into a 3" exhaust with Borla race mufflers and x pipe
The car weighs 3400lbs with me in it and is getting a dana with 4.10 gears
Car has a 28x12.5 ET street bias ply and has the full caltrac setup out back, with calvert 90/10's up front, 6cyl torsion bars and adjustable upper control arms
Transmission is a a chrysler 4 speed 2.66 first transmission with a centerforce dual friction clutch and a v-gate shifter with two step (hopefully will help with consistency some and not missing gears)...Im a pretty good driver and at the track the gas will be matted 110% of the time
lets hear it! hopefully my hopes for it are close to what it should run
