1 - 9 of 9 Posts
Do not understand the weight. Says baseline 101, weighs 3100, then it says 88 add 100, 94 add 150. What does a 101 with a small black have to weigh in 28 vs 275?
ROLL TIDE!!!!
single turbo (SB only)- 3000lbs base weight with 80 mm
single turbo (sb only) 3100 lbs base weight for any (101 or bigger that is being reduced )
add 100lbs for bigger than 80 mm
add 150lbs for 88 mm
add 200lbs for 94 mm
add 50lbs for non inline head
deduct 50lbs for non intercooled
add 50lbs for non stock suspension, must have stock frame rail - notch okay
no weight break for tip to tip single turbo entry
Your base weight for SB with a 101 is 3100. What are you reducing it to?
94mm as the actual size.
Please call me because im confused about what size turbo you are trying to run.
813-927-2842
if its a true 94mm then 3200lbs not counting for heads, suspension or other stuff
if its a 101mm reduced to 94mm then has to weigh 3300lbs
TRZ Rocks!
for you rick....call it an even 3400:p
Discussion Starter · #8 ·
Going testing with billy 94 this weekend see how it goes should be heading to sgmp thurday see you their will be on 28 will be a frist round duck cant wait
1 - 9 of 9 Posts
