1 - 13 of 13 Posts
are being used in the fastest DR cars??? brands? number of splines? just comparing and trying to figure out what we should get
Bring on the Metal!!
Usually 35 to 40 spline. I would wager to say there is a melting pot of all manufacturers, I know that's what i've seen. I use either Strange or Moser, depending on what the customer prefers.
Mark Williams, strange, or Moser. Mark williams has some crazy options if you got the cash to burn.
thanks for the replies guys... and what about the center sections, i'm guessing yall are staying away from alumnium???
strange aluminum 3rd member here with 35spline. Everyone I know runs aluminum .
Discussion Starter · #9 ·
Discussion Starter · #11 ·
hey denny i see you lurking... what are yall using on will's car?
so no aluminum cases and no aluminum spools???
The Strange Ultra-case is Aluminum. I've only sold one aluminum spool for one of these so far as the customer wanted to give it a try and see if it would hold up in one of these cars. He's made a few hits with it and so far so good. Car runs 7.70s-60s at 3200lbs so it will test it pretty good.
Discussion Starter · #13 ·
oh alright i'm thinking of the nodular iron case from strange... thanks everyone for the replies... helps a lot
1 - 13 of 13 Posts
