1 - 20 of 27 Posts
BBC w/single turbo,power glide trans,3100-3200 lbs,33x10.5w tires,4 link,roughly 1800-1900 hp. just did a new transmission and converter.what fluid whould you guys use?
Non-synthetic Type F
When I raced Outlaw Pro Mod with a BBC with twins and Rossler 210 we always ran Tractor Fluid from Central Tractor supply or John Deere Trans fluid.
Survived Drag Week 2018
John Deere Hygard!!!!!
Satans Daddy
Tractor fluid if you can afford a tighter convertor, makes the planets happy happy happy, run a heavy duty cooler though, and extend your puke line to the rear, preferably in a tank.
amsoil synthetic compressor oil. Pick your viscosity to suite your application
Oh boy.... 2 flaws here.
ScAmsoil and extra slippery tranny fluid.
This amp goes to 11.
Might ask the trans builder what they prefer you use.
Trans fluid, engine/gear oil, it’s all a sales gimmick. Water works just as well.
And if you mix water & oil in the pan, you'll get a milkshake. Nothing like a tasty treat after a long hot day of racing!
1 - 20 of 27 Posts
