How's this for fuel economy device?
http://www.loneinventor.com/ftopicp-122.html
GAS-SAVING DEVICE =KHAOS Super Turbo charger=
Inventor: Pablo Planas
FREQUENTLY-ASKED QUESTIONS
What is Khaos Super Turbo Charger (KSTC)?
· KSTC is an air regulating device which introduces the right amount of additional air to the engine to obtain the proper air-fuel ratio for better combustion. KSTC has been cited with a Presidential Award as the Most Outstanding Invention for Transportation & Environment during the Filipino Inventors Week, Nov. 26-30, 2003 at Philtrade, Philippines.
How does KSTC differ from other existing anti-pollution & gas-saving devices?
· KSTC is a mechanical device and does not require any chemical additive to function. It is made from high grade materials and only requires minimum maintenance.
What benefits can be expected once KSTC is installed on gasoline vehicles?
· As an anti-pollution device, it minimizes the pollutants carbon monoxide and unburned hydrocarbons to less harmful levels. The National Pollution Control Commission test results and that of the Automotive Research and Testing Center (ARTC) in Taiwan show that Khaos can actually bring the carbon monoxide concentration to almost zero. Since KSTC promotes better combustion, it saves fuel, increases engine power, and can prolong the life of the engine, spark plug, and engine oil.
How does KSTC differ from a catalytic converter since it is also an anti-pollution device?
· A catalytic converter is a post-combustion device that reduces pollutants by chemically treating the exhaust gases. KSTC is a pre-combustion device that promotes better combustion to minimize unburned fuel in the exhaust gases by ensuring that the air-fuel ratio within the proper range prior to combustion.
Does KSTC increase engine power?
· Instantly! An increase in engine power is immediately felt right after installation because the correct air-fuel mixture for better combustion is attained with the device. Better combustion means more power.
Has KSTC been tested abroad?
· Yes KSTC has been tested by reputable authorities abroad. These include Vipac Engineers & Scientists Ltd., Approved Research Organization (Melbourne, Australia) which tested KSTC in accordance with ADR79/01 & ADR81/01; and Automotive Research and Testing Center (Taiwan) which followed Taiwan EPA regulations. All tests showed substantial fuel savings and big drops in carbon monoxide and hydrocarbon levels when KSTC was used.
Where do you install the Khaos Super Turbo Charger?
· KSTC is installed at the intake manifold of gasoline vehicles, either carburetor or fuel-injection type. Installation takes only 30 minutes.
Is tune-up or adjustment of the engine necessary before the installation of KSTC?
· Yes, KSTC mechanics check the engine first before installing the device.
How much gasoline can we save once KSTC is installed?
· Tests have shown that a gas savings of up to 50% can be achieved. An average of 25% gas saving is usually observed.
How long does it take to recover the investment in a Khaos Super Turbo Charger?
· Return on investment is typically less than a year. It depends on how much you drive and on your gasoline savings percentage. Other benefits such as prolonged life of your spark plugs, engine oil, and the engine itself make the investment even more worthwhile.
What vehicles can be installed with KSTC?
KSTC can be installed in any vehicle with a naturally aspirated gasoline engine (carbureted or fuel
Injected).
Testemonials:
Quezon City Mayor Sonny Belmonte
Vehicle type: Toyota Revo
Gas Savings: 25%
Energy Sec. Vince Perez
Vehicle type: Honda Accord
Gas Savings: 50%
Onemig Bondoc
Vehicle type: Jaguar
Gas Savings: 30%
Sheree Bautista
Vehicle Type: Toyota Altis
Gas Savings: 25%
Hon. Vice – Pres. Of the Philippine
Noli De Castro
Vehicle Type: Suburban
Gas Savings: 39%
Khaos Super Turbo Charger USD $ 275
Free Shipping World-Wide.
Delivery Immediately after the Receipt of Payment
Money back guarantee
To order Khaos Super Turbo Charger, just write down on a plain paper your name, complete postal address and e-mail address. Wrap one USD$275 bill with the paper (you can use double paper of any dark color), put in an envelope, glue well and send by REGISTERED AIR MAIL to my address below: We do not accept Cheque
We Accept Postal Money Order or Cash
Payable to: ROMEO SAJULGA
