Needed to know what spark plug i should use. I have a 1993 Mustang with AFR 165 heads and S trim supercharger on it with stock bottom end and a F cam on it. I just got this engine put together and it's in the car now. The car should make about 8 to 10 psi. I'm still trying to find the right spark plug for this set up. I use NGK FR5 on my other Mustang that I run at the track. It has a T trim 12psi,Q16 gas,Vic Jr heads on it,A4 block. So what do u guy thinks I should use for spark plug on this set up???? Thanks
