Morel has them I know for sure, pretty certain Jesel has them also. Crower maybe.PI ls7 heads, with the heads on the block it looks like I'm going to need a set of offset lifters.
What brand lifter and how much offset?
Part #?
Ls motors don't have offset lifters just offset shaft rockers. If your looking for a set of solid roller lifters the Bullet/Morel pro series 5425 are a good choice.PI ls7 heads, with the heads on the block it looks like I'm going to need a set of offset lifters.
Part #?
Part #?
Factory and most aftermarket Ls7 heads are .350 offset on the intake rocker side and .050 on the exhaust side.Pretty sure Bullet/Morel has an offset version for LS engines as well as standard lifters. not sure those heads require the offsets
Thanks for the info Kurt.Most square port stuff can get by without them when using small pushrods, but once the 7/16 or 1/2 pushrods go in with large port heads offsets are required to get space and straighten out the pushrod.
Kurt
At what point do you go from a .842 lifter to a .904 lifter? I'm running a 6.0 iron block, can you bore the lifter bores to except a .904 lifter.Jesel, Morel and Isky make offset lifters for that set up. Jesel may have link bar type, but they for sure have dog bone and key style. The Morel stuff is link bar, the stuff I use is .904 diameter on the Morel.
Kurt
should be able to get them bore. if I was running near .900" lift with 900 to 1000lb spring pressure, would be smart move to install larger liftersAt what point do you go from a .842 lifter to a .904 lifter? I'm running a 6.0 iron block, can you bore the lifter bores to except a .904 lifter.
I'm at 306/810 on spring pressures and .810 lift before lash. I have the Morel .842 pro series lifters right now.should be able to get them bore. if I was running near .900" lift with 900 to 1000lb spring pressure, would be smart move to install larger lifters
Keep rockin' what you have. You'll be fine.I'm at 306/810 on spring pressures and .810 lift before lash. I have the Morel .842 pro series lifters right now.
You should be good with thoseI'm at 306/810 on spring pressures and .810 lift before lash. I have the Morel .842 pro series lifters right now.
Thanks BillyKeep rockin' what you have. You'll be fine.![]()
Thanks SamYou should be good with those
