1 - 3 of 3 Posts
430 inch sbc 23 degree heads 1050 dominator
Bullet solid roller nitrous grind
3 speed trans and 4.10 gear
car is 3170 with driver
nitrous plate system (200- 350)
28 inch tire
what diameter converter do i need for this combo??
have an 8 inch ATI on the shelf but dont know if it will work
please advise as to what diameter and how do you determine what diameter converter to use
Need more detailed information on your combination... what does the engine make itself, how well does the car hook/what rear suspension, intended use of the car (class/brackets/etc). Without that it's a tough guess as to whether to go with an 8" or a 9" converter.
1 - 3 of 3 Posts
