how the phuck do you figure that?you drivin in reverse
Once a tire locks up, its drag goes to almost nothing (reverted rubber hydroplaining)
Lock the fronts up while the brear tires still have traction and the greater drag rears stay behind the lower drag fronts.
Lock the rears up, and the front still has massive traction due to weight transfer and the rears have no traction to keep force the car straight, and the fronts will try to go to the opposite of the traveling direction (higher drag always trys to go to the back).
Try it in a car with a hand E brake on a wet day. Get in the brakes hard and stay on them while pulling the E brake and lock the rears. The car is going to try to swap ends, and fast until you gain traction on the rear tires by releasing the E brake.
This is why getting on the brakes when the rear tires are spinning from too much HP is always going to put the car into the wall. The car comes around almost instantly and once pointed a the wall people realize the brakes caused the issue and they get off the brakes, the rears gain traction amd the car regains control, but in a very bad direction.
