1 - 7 of 7 Posts
What is the recommended size hose to vent crankcase pressure? Looking to vent from valve cover to breather catch/can. Will a -10 suffice or does it need to be bigger?
Running a -12 after advice from here. Goes into a small ally tank with a drain.
Okay it seems the consensus is -12:D
Does it matter wether the hose is rubber or braided steel? I want to use this Moroso can.
1 - 7 of 7 Posts
