1 - 7 of 7 Posts
More info is needed. Any power adders? About 900 HP I assume. If no power adders are used and this is all motor, the true 9 is going to be the winner.
correct 900hp maybe 150 hp spray i have a 8in didnt know if i should buy a 9 in the stall is in the right range thanks
9.5" without the spray and 10" with the spray. You have a somewhat simple combo with a couple hundred extra pounds!:)
The S98 Toyota type core works very well in the bigger stroke-heavier combo's. The variation of stator types along with it's ability to hold approx. 5 qts. of fluid give this piece a distinct advantage. This all depends on your overall combo-ie heads, cam, intake,gear,tire etc. and RPM parameters. The S98 term comes from the size or distance across the turbine face, as all converters are and should be measured.
1 - 7 of 7 Posts
