1 - 15 of 15 Posts
~800rwhp now ~1200 later
My turbo has a 3.5" outlet and my throttle body is 4"
I have a bunch of 3" or 3.5 or 4?
With those power goals i would go with the 3"
I wouldnt neck down the turbo outlet.
Do you have an intercooler?
What intake TB setup?
Anything that would hurt me by necking down the turbo?
No because chances are that you may have a 3.5" outlet flange put if you measure the actual hole its probably smaller then 3"
Discussion Starter #8
Turbo is a gt5518 and the intake is stock lq4 truck I take
No intercooler running straight into intake and running e98
Run it in 4 and be done.
Gigity
I did a 3.5" on my 6.0/S480 setup, for the simple reason that my turbo outlet is 3.5", and my carb hat inlet is 3.5". It makes ZERO sense to me to neck it down.
1 - 15 of 15 Posts
