1 - 3 of 3 Posts
Hay guys, I was wanting some feed back on the size cam I should run to get the most bang for my setup????
454 .030 over flat top pistons, allunimum heads 2.25 int, 1.88 ext, 850 holly DP, 3,500 stall, turbo 350, 430 gears. Summit billet distributor, I will be running a 150 shot at some point but want a cam that will work well with or without the NOS. This car is for the strip only no street. Oh and the heads are good up to a 650 lift, and have 115cc chambers.
1 - 3 of 3 Posts
