1 - 14 of 14 Posts
Getting ready to start ordering parts gonna be a 6.0 with mild cam 2 1/2 hot side and s475 turbo with 60mm waste gate. What size BOV should I order?
Long Live The King
any other info on this topic ?
Is there a proper way to size a BOV ?
I'd think that once it blows, even if the opening was the size of a dime or nickle the psi would drop instantly. Or is "bigger better" depending on the size of the system ?
Can't go too big. I usually match them up. I ran 60mm BOV and 60mm gate on my single setup. Now on twins and just added one more of each.
I had a jgs 60mm on my old setup with s475 and 3" cold piping.
Phuck me what's a BOV :p
Discussion Starter #12 (Edited)
Just bought all my parts the other night. I ordered a cheapo 50mm blow off, got two xs power 60mm waste gates off c list for 150 bucks, ordered a air to water inter cooler an ice box with rule 2000 pump. Also ordered an ordinary s475 turbo ,aero motive boost reference fuel regulator, and a holley fuel rail kit. I plan on mounting the intercooler behind the pass side seat and just flipping my intake around backwards. And running the intake piping through the firewall. But then where should I place my bov? I heard they are suppose to be after the intercooler but then the only place to mount it would be in the cab somewhere which I would like to avoid. I've also heard good things about custom ground turbo cams. Any recommendations on who/what brand to use???
Discussion Starter #13
Also pne of the waste gates was disassembled when I got it and is missing a piece that goes inbetween the spring and the top of the wastegate. Does anyone know what talking about or if can order one of these parts?
Long Live The King
All you need is a 50mm, don't know why guys are bringing up huge blow off valves.
I ended up ordering a TiAL Q 50mm today.
It's rated to 1,800 they say so I'm good ;)
1 - 14 of 14 Posts
