1 - 20 of 23 Posts
I recently finished my 70 nova.... car has a 565 with brodix -2x heads (345's) unported, 12.5:1 comp., bullet custom ground solid roller over .800 lift, ported sniper intake, speedtech diffuser plate, glide with neal chance convertor, 4.11 gear, 29.5 10.5 slicks, 3200 car and driver
With a 92 pill in the plate what do you guys think my car should mph (1/8th mile)?
forgot to mention the exhaust on my car is kinda small, hooker competition headers 2" or 2 1/8th" with 3.5" spintech mufflers. I know this is probably hurting the mph some...
What's the rpm drop on the gear change Mikey?
I honestly couldnt tell ya... where the tach is mounted I cant really see rpm going down track just the shift light. But I have tried 2 different neal chance convertors (one out of uncs car) and still runs less mph than I think it should.
I would say 129-131
Call Lane at PTC he will help you anyway he can (256) 383-6868
Discussion Starter #8
My car on a 92 jet is only running 122-123.... I feel like it should run faster than that even though like I said I know there is a few issues that hurt the mph (small headers, unported heads, etc) I still think it should go more mph.
What also seems weird to me is I have ran similar combos in other cars and always leave on 40-50% on the controller and dont pull out any extra timing. This thing I can leave on 100% with no extra timing pulled out and it still doesnt 60' great (1.29) best so far.
Im currently moving my progressive controller away from the ignition box as I have heard this car cause interference. Gonna try that and see what happens.
There are just too many variables to try to guess. Usually people set themselves up for disappointment by building up an expectation in their head. Take it out, run it, and go from there...most importantly have fun with it.
RED ROCKET
sounds alot like my loaner motor..126 to 128 every pass..
The Brodix -2x heads just don't flow that much might work good on motor but they need some help on nitrous.
Discussion Starter #16
Still say it's the progressive...remember what mine did? Ran 120 no matter what. Picked up 5-6 mph just from moving the progressive and the wiring.
I went 5.62 @123.xx with a 1.30 60' . Mine has a 32 jet in the Fogger and the progressor was on 20% for 2 sec. 18* 421. Looks like ur numbers are close to mine....
Discussion Starter #19
I moved it last night david.... moved it onto main hoop behind the passenger seat and loomed all the wires together and away from everything. Hopefully it helps a little.
Discussion Starter #20
See thats what I think is weird, your leaving on 20% and ramping it out and I can leave on everything and 60 ft the same.
1 - 20 of 23 Posts
