I've done about 10 firewalls.I never had a problem.Time consuming cause its mostly by hand.I use Rage filler and Evercoat polyester glaze.Southern Polyurethane 2K primer over the bodywork and their epoxy primer over that.Any imperfections are fixed with the glaze.I used the Scott Rod Panels on the front of the inner fender well.They work great ,great fit.They save lots of work.The rage gold is what I was thinking also.how is the shrinkage?
EXACTLY right on the money!!!Shrinkage usually isn't a body filler problem,....both the plastic, (Rage), and the finishing putty, (Icing), have hardeners or catalysts, which cause them to chemically dry, not "air" dry,......and they won't shrink.
The shrinking is usually cause by the primers you use over the fillers, (even though these have catalysts, too). The wrong stuff, or the wrong application, is what causes improper drying and hardening,....which results in shrinking later on after paint,....because what's under the topcoat is still drying.
"Alpha-Kryl"!!!EXACTLY right on the money!!!
Shrinkage WAS a problem with the old squeeze tubes of stuff.
(Do you remember the yellow tubes of red stuff?)
I can't remember the name off hand...
Shrank like a MOFO!!!
Your Pal, Gary
if you were and good you did not need any of that crap in the tubeEXACTLY right on the money!!!
Your Pal, Gary
Great product,also try u-pol's Fantastic filler,you'll never buy rage again.How do you guys feel about Dolphin Glaze? The local place swears by it and stocks it, so we tried it and it's worked well for glazing and small touch ups on molds. It's reasonably priced and we don't use a whole lot of it. Skimming small dips that are less than paper thin or filling little gel coat blistering on plugs is usually what we use it for. It seems to bond to un-scuffed gel coat and sheet metal parts pretty well. Opinions? Funny side note, in the shop, we all call it "Dolphin Jizz".
