1 - 13 of 13 Posts
T/S 368E
Going to an estate sale and they are advertising some of the blocks are tall deck??
These will turned into 850-900 HP drag engines, I was always told some are strong, some are junk and thin???
Thanks Guys.
T/S 368E
Cash & carry.
We were also always told that some stupid alphanumeric digits on "insert block here" meant it has "high nickel" and so, it's harder than a regular block. Yet here we are in 2022 and NO ONE has verifiable proof that its a fact. Because it isn't. It's nonsense that people repeat because they've heard a million times.
And it's always been nonsense. Just because you hear it 50k times doesn't make it true. Just FYI. Take things "everybody says" with a grain of salt without some sort of self-verification that it's actually true.
Being an auction you'll need something quick and crude for checking core shift. Hopefully it's a bare block or at least the flexplate is off. On the back side take a look at the cam boss cast into the block. Try and see how close the cam plug is centered in the boss. It's a good "indicator" of core shift. It will show core shift up or down and left or right. Good luck!
T/S 368E
Discussion Starter · #7 ·
Thanks Guys!!!
Thanks Guys.
if you raced as much as you talk, you'd be another FORCE.......
I can't believe how much you talk without pictures of action........\
just another NasttyZ wannabe...... am I wrong?\
38 thousand posts..... and I will be willing to bet not one of a race and less than 5 of an actual race car.
T/S 368E
Discussion Starter · #9 ·
There's 10 pages of stuff for sale.
FORD 351-400 M D7TE-A-2B .030 H.P. BUILD REBUILT LONG BLK.77-82351/400M 2 BOLT TRUCK 4000 1
100 PONTIAC 455 4-BOLT 1974 485428 4-BOLT Y9 BLOCK ALINE BORE NEEDED 2500
101 FORD 351- C DOAE-L 2-BOLT 1970 BLOCK RUSTY NEEDS BORE 70/71 351-C 300
102 FORD 351-C DOAE-L 2-BOLT DUPLICATE ?? 70/71 351 - C
103 FORD 351-C STD BORE D2AE-CA 4 BOLT BOSS BLK. 72-74 ARE H.O. BLOCKS C.J. MOTOR H.P. BLOCK C.J. / BOSS 500
104 FORD 351-C CHECK CASTING D2AE -DA/EA 2 BOLT 1972 ? BARE BLK. 1972 400
105 FORD 351-C CHECK CASTING ????? CA = COBRA JET MOTORS
108 FORD 5.0 F.I. 4 BAR HEADS F18E LONG BLOCK ON STAND 1600
110 CHEVY 454 STD. DECK 2-B 14015445 .030 NEEDS ANOTHER .030 VERTICAL SCRATCHES .030 VERT SCRARCHS DECK & LLINE SOLD? FLORDIA 700
111 FORD 4.6 32V IKJGHH3 CHECK DID I JUNK OR ON FLOOR 200
112 / 179 CHEVY 454 STD. DECK MK V 10114182 2-BOLT .030 REBUILT BY G.M. GEN V NEEDS ANOTHER REBUILD 200
113 FORD JERRY MOTOR DIVE A28 429 T-BIRD S.B. 1969 BARE BLOCK STD. BORE RUSTY 71/78 429/460 400
114 CHEVY 396 2-B STD.BORE 3969854 1968 2-BOLT ???? SEPT. 27TH. 68 MISSING REAR CAP ALINE HONE 600
115 CHEVY 454 STD. BORE 2-B 361959 1975 L.D. TRUCK 2-B SHORT BLK. FROZEN PISTIONS 600
116 FORD 4.6 21222222B1 SHORT BLOCK DUPLICATE ????? JUNKED ????? 200
118 FORD 302 ROLLER E7AE-CA/EA? BARE L711 12-11-87 BARE BLOCK W/CAPS DUPLICATE?? 1987 150
119 CHEVY 350 WAYNES BLK. 3970010 4 BOLT BLOCK ONLY STD. BORE 300
121 2 UNKNOWN MOTORS
121-A 2 UNKNOWN MOTORS
122 CHEVY 366 TALL DECK 4-B 364779 1978 LONG NO INTAKE FORGED CRANK OVAL 600
123 PONTIAC 455 - 4 BOLT YE BLOCK = 197O H.O. HIGH PERFORMANCE MOTOR 4000
123A PONTIAC 400 DO I HAVE A 400 MOTOR
125 PONTIAC - 400 DITTO 132? 481988 73 400 NO CAPS WHAT MOTOR DO I HAVE 500
127 CHEVY 396 402 2-B 3902406 1967 .060 LONG BLK. OVAL REBUILDING NOW CHECK DUAL QUADS??? 400
126 PONTIAC 400 2-B 500557 STD. HI87 BARE BLOCK SEPT. 18TH 1977 SEE SHEET 400
128 FORD 351-W 2BBL. ????? - 6015-B 1968-69 ON STAND COULD BE 302 W/ 351 HEADS???? 2000
129 CHEVY 350 4 BOLT INVADER 3970010 ORANGE, STD BORE HAVE ALL PARTS AFTER BORE HONE NEED NUMBERS.... 2000
130 CHEVY BB 1972 BLK. 3999290 FIND IN SHOP FIND IN SHOP
131 CHEVY 454 STD. BORE 3999289 2 BOLT VETTE MOTOR ? BARE BLK. 1972 500
132 CHEVY BB 427 T 10114184 GEN V 1995 IN PLASTIC 2000
133 CHEVY 402 1972 3999290 2-B .060 REBUILDING RECT. PORT HEAD TUNNEL RAM 4500
134 CHEVY 396 .030
134 CHEVY 396 .030 2-B 3902406 .030 1967 MOTOR SOLD
135 CHEVY TALL DECK 427 340220 1970-74 4-BOLT DEC. 18TH. 74 MISSING ALL CAPS ALINE HONE 3000
136 FORD 429/460 TRUCK 2-B D9TE-AB XXXX BLOCK H.P. 77 BLOCK WINDAGE TRAY H.P. SAVE 79/84 CHECK 250
137 FORD NOTCHED 1980 EOSE-A2E 255 W 2 BOLT 611 IN VALLEY 0G106749 BLOCK 255 CID JUNKER?? 500
138 PONTIAC 400 481988 2-BOLT NOV 15 73 SHORT BLOCK 600
139 FORD 351-C 1970 STD. BORE DOAE-L 2-BOLT70 MUST/TOR BARE BLOCK 70-71 351-C 600
142 CHEVY 396-402 1969 STD DK 3969854 2-BOLT ILL RESTAMP ????? DUPLICATE 2500
143 CHEVY 454 STUDS SOLD 14015455 .120 O-RINGED BLK FILLED SOLD
144 CHEVY 454 STD BORE 14015445 2-BOLT-1 PISTON MISS SHORT BLOCK 600
146 CHEVY 400 4-BOLT 3951511 1972 BARE BLOCK, RUSTY 500
147 146 CHEVY 5.7 ROLLER 14093638 1994 BARE BLOCK 250
149 CHEVY 5.7 ROLLER 10125327 LT-1 SOLD CHECK ??????
150 CHEVY 400 2-BOLT 3951509 STD BORE BLOCK ONLY STD. BORE 450
151 PONTIAC 400 500557 YC CODE 2 BOLT 1975 7K3 HEADS 500
152 PONTIAC 400 500557 Y4 CODE 77 B-BODY LONG BLOCK 2500
154 PONTIAC 350 6 WHEEL 488986 WITH CLUTCH YA SALT 1-PISTON MISSING 500
156 FORD 302 2-B D2OE-AB 1972-74 302-W 2 BOLT SHORT BLOCK W HEADS SOLD???
157 PONTIAC 326 9786339 PATCH IN VALLY YN MISSING ONE PISTON 1967 2500
158 CHEVY 305 14010201 84 GOLD VALVE COV. LONG BLOCK MISSING DAMPER 350
159 CHEVY 350 ROLLER 10243880 4-BOLT 1PC. SHORT, ROLLER 1986 400
160 CHEVY 350 3970010 STD BORE 4-B MAY HAVE SOLD IF NOT FOUND
161 PONTIAC 400 9790071 XZ CODE 4 SPEED 68 GRAY GTO?? COULD BE, COMPLETE keep
163 FORD ROLLER 5.0 MAY HAVE SOLD IF NOT FOUND
165 CHEVY 454 2 BOLT 14015445 STD DECK .030 REBLT. VERY RUSTY NO CAPS?? ALINE 500
166 CHEVY 454 BOAT MOTOR 14015445 STD. BORE 72 OR 82 MISSING 1 ROD & PISTON RUSTY 500
171 PONTIAC 400 481988 YN CODE 1972 MOTOR WINDAGE, LONG, 2 BOLTN CRANK SEE SHEET 700
172 PONTIAC 301-TURBO 10000516? MISSING PARTS MAY BE JUNK FULL OF WATER 200
173 [PNTIAC 350 9790079 67 350 MAY HAVE JUNKED
174 FORD 351 W E3AE AA/BA WHICH ONE AA/BA SOLD IF NOT FOUND 1983 2 BOLT
175 FORD S.B. 351-W 84/91 E4AE FA WCP4 CAST IN VALLEY SOLD IF NOT FOUND
176 FORD 351-C 2-B DUPLICATE DOAE-L Dec-70 LONG BLOCK STD. BORE 70 / 71
I wouldn't waste any money on the old truck blocks...most had very thin cylinders and all have the oil galley on the pan rail. Yeah, some will come on here and brag about how good they are, they made XXX hp and no issues, blah blah blah....they are fine for stock and mild performance builds, but nothing serious. I'd save my money and get a decent block no matter the price difference.
1 - 13 of 13 Posts
