1 - 7 of 7 Posts
building a 1000hp street car that i would like to drive to the track on pump gas turbo. what would you guys suggest for a trans t400, glide, 350?????
A 4r70W with the aod {2.40} gear set. All the th400 ratio's with an added bonus>> overdrive. If you want to keep it simple, you couldn't go wrong with a TH400. If the car is light then, PG.
Mike.
From what you asked , it will be a decision between the T400 and the glide. Forget the 350.
Now you have to decide whether you want the best performance at 1000hp with your given tire size, suspension etc or if you would rather have 3 speeds for moderate driving on the street.
Hutch
Discussion Starter · #4 ·
stock susp. DR
Sounds like a glide may be the best fit. SFI case, bellhousing etc. will be a nice install and requires no shields. Im assuming it has a stock floor.
Hutch
yes with Through the Floor Subframe from wolfe
Banned
Reid case glide.
Get it from Hutch.
1 - 7 of 7 Posts
