1 - 5 of 5 Posts
Hello
I wonder what kind of timing you run on 25-30 psi boost? I´m running 26 degrees total timing (compression is 8.8 ).I have som issues with the plugs, and the fuel is E85. I have spoken to Pete at PTE and he says that 26 degrees is to much timing, what do you think?
Thanks Robert
I was under the impression that E85 had an equivalent octane rating similar to 104 or 106 race gas. I thought I read an article in Hot Rod a few months back where they did some dyno testing on both fuels and found similar #'s on less boost with e85 for that very reason...did I read that wrong?
1 - 5 of 5 Posts
