1 - 3 of 3 Posts
I HAVE A 439SBF WITH A 106MM AND CURRENTLY RUNNING TRICKFLOW R HEADS THAT FLOW 365 @ 750 AND 280 EXT. I AM THINKING OF CHANGING HEAD SET UP AND WOULD LIKE TO KNOW WHAT WOULD BE A GOOD SET OF HEADS TO THROW ON THERE. I KNOW I WOULD HAVE TO CHANGE HEADERS AND OTHER STUFF BUT THATS OK JUST WANT TO GO FASTER. :confused:
first off what do the class rule say
second can you get more out of those heads , many others are going very evry fast on those heads
some time looking at other oppition for tuneing can be cheaper and yeild good numbrers , like redoing you torque convertor , and working you susp. , better 60 ft , ive seen those heads flow as hi as 400 cfm , what vavle size are you useing
third if you want to change the heads there are many good heads out there , yates, brodix 202 , the edel. yates , some others that are not coming to mind know , do a search on here , you'll find more info
How fast is the car already? I'd stick with those heads if they work. Just turn up the boost and that 106 will make near 2000 hp on that motor.
1 - 3 of 3 Posts
