Which is a better cooler a tube and fin? Or a stacked plate i.e. B&M super cooler?
says the guy who put the smallest cooler in the world on his car...:-DFin n plate is far more efficient than a tube cooler.
when you are on the brake those coolers will never cool the oil enough. Temp gets up to 400deg in an instant inside the converter with a supercharger/turbo .
I've always had success with tube and fin I'm leanin hard to go back ...a peace of mind thing . It seems to be clean and flow ok.Stacked plate will clog up eaiser in case of some sort of failure. A tube, although less efficent will pass larger crap through it.
If you have room pick up a ford f250-350 "v10" cooler. It is huge and will cool like the dickens...yes the dickens.
