1 - 5 of 5 Posts
I am getting ready to assemble one of my motors but I want to check to see if the deck is true.
What are some of the ways to check this?
-Eric-
Eric:
The only way you're going to do this in a garage at home on an engine stand is with a straight edge and feelers.
You can do smaller areas with a bridge & indicator but you really have to be able to check a span as long as your cylinder head to see anything meaningful.
Approx. .003" max out of flat is about all that you'll want to see.
Premium Member
Well, I wouldn't just use a good piece of metal as a straight edge. You really need something that has a machined edge. You may think you have a good flat piece of metal but .010 out and you wouldn't see it.... and you'll have a false reading.
deck
Are you trying to find out if the deck is flat or if it's the same distance from the crank centerline on both sides, front to rear????
Keith
1 - 5 of 5 Posts
