1 - 5 of 5 Posts
I HAVE A MALIBU WITH TWIN TURBO IN THE WORKS AND I NEED TO KNOW WHAT GEAR RATIO I NEED. ITS A 350 TWIN 70MM TURBOS WITH A CARB SHOP 750 BLOW THRU HOLLEY HOPIN TO MAKE 700HP.
Lots of variables determine what will work best for your setup (weight, transmission, power, launch rpm, etc). If it's an 1/8 mile car, 4.10 gear or 1/4 mile car, 3.55 gear. This is what my car likes!
IMO, set up the gears like you would a N/A setup. Figure out what rpm you are going to shift at and what rpm you want to go through the traps at with with your tire size. Don't get caught up in the 3.08/2.73 gear to "load" the turbo!!
THIS IS MY FIRST TURBO PROJECT AND IT IS 79 BU, 350 TRANS, 350 TWIN TURBO, STOCK WEIGHT CAR AT THE MOMENT. MY BROTHER WITH A 94 S-10 WITH 383 IS GIVING ME HELL ABOUT IT CALLIN ME SLOW BU, I HAVE TO SET HIM STRAIGHT. HE'S 10.9 ON MOTOR WITH 2 KITS WAITIN
im using 3.50's in mine...heres some quick advice 434bu..hit the newbie thread and make it official..if not it can get real ugly..keep us posted on the build
1 - 5 of 5 Posts
