1 - 9 of 9 Posts
I am trying to figure out what fuel would work best in my combo. E85 - Q16 - C16 ?
SBF 400"
10-1 Comp Ratio
F1R Cog set up 77/44 6900k @ 7800rpm
A/W intercooler
Bosch 160# injectors
105mm Wilson TB
4" Tubing from Head To Blade
"what fuel would work best in my combo"
For what kind of application? What are your goals?
Blessings.........Ron
SBF 400"
10-1 Comp Ratio
A/W intercooler
105mm Wilson TB
goal, to run it to its potential.
Procharged SBC Enthusiast
I run Q-16 . Makes a bit more power than C-16. Just does not last after the can is open , kind of like a carbonated beverage .
C16 is probably easiest, easy to find and no problems storing it. Previously in NMRA it's the only legal choice, don't know if that's still the case. The Q is oxygenated and will require additional %'s over the C, if fuel volume might be an issue. I wouldn't touch E85.
1 - 9 of 9 Posts
