1 - 10 of 10 Posts
building a 540bbc with 11.8-1 static cimpres./748 lift roller/ported and flowed brodix heads/12-71 alcohol blower at 20%OD/B&U ALKY HAT//pg trans with brake/no converter yet/4;30 gears with spool/
car is chassis car weight should be in the 2700lb to 2900lb area..
drine line needs to be 53"from middle of joints
should i go with 4130 or aluminum or what on driveline?
also what rear end yoke and what slip yoke should i buy?
don
badtoyzz racing
You need a CM drive shaft and the typical steel yokes. Just get them from whoever makes your driveshaft. I'd call Denny's if it were me. But Moser, Strange, etc. are other possibilities.
1 - 10 of 10 Posts
