1 - 15 of 15 Posts
STREET ROLER / Performance Level 4
- Intended for performance oriented hotstreet
applications. 8620 steel billet.
RPM Power Range: 3250 to 7250 / Redline: 7750 maximum.
Grind Lobe Center Adv Duration Duration @ 050 Lift 1.5 rocker
290R 290 260 585​
112° 296 266 597
Or: MECHANICAL ROLLER-Best for Pro Street 3200 to 7200 XR292R
Adv duration Lift Duration @ 050 Lobe sep
292 297 .582 .588 254 260 110°
I run a B&M Holeshot 3000, 4.10 gears, 28" tire. Vehicle weight 3500 lbs.
Motown 220's 2.08 Intake 1.60 exhaust
Motown Single Plane
10:1 Compression
The cam thats in there right now is 525 / 516 lift
244 / 252 @ 050
Hydraulic Flat tappet
I already have 1.6 rockers
I have the Comp Cams XR286R solid roller in my street car with 356" Windsor. Real nice crispy idle and fast throttle response.
10.62:1 compression, Canfield heads and Super Victor intake by Rodger Heldgeson, TREMEC, and 4.30's., full exhaust, 10.60's @ 127 (no power adder), drive anywhere anytime.
MECHANICAL ROLLER-Good
lash int .016/ exh .018
3000 to 7000
248/254 @ .050
int.614/ exh .621
LSA 110°
weekend warrior with 3000 or more
stall. Needs aftermarket intake and
exhaust with low gears.
Just want to upgrade my hydraulic flat tappet. Hydraulic rollers don't RPM, so I thought a solid roller would make a bit more horsepower.
Dave
That would normally be true. I assume you are talking about a complete cam and kit including springs and retainers.
The big advantage with a roller cam is valve opening and closing rates. Even a cam with the same listed duration @ .050 might show an improvement in Hp as it give the motor more time to breath. You don't have a ton of compression and you have a heavy car so don't go over board.
Hydrualics can RPM just fine if you know how to pick the lobes and springs and keep the valvetrain light and stiff. No trick parts needed.
Dave
I think your second cam would work pretty decent but like was posted before I don't think you'll ever get any good power @ 7000 with it .I ran for years with a low compresion 406 sbc and I ran a bigger cam than this one you've picked out . Jus run this one if you have it .
""MECHANICAL ROLLER-Best for Pro Street 3200 to 7200 XR292R""
Discussion Starter · #12 ·
I agree it won't make power to 7000. When most cam company's rate their cams from lets say 3000-7000, thats rated in a 355. That same cam in my 427 might make power from 2500-6500. I am just saying if i am going to upgrade the cam , I should go solid roller for more power.
Dave
There's no such thing as a street solid roller, no matter what the ads say. Solid rollers are for racing. If you do any amount of extended street driving, especially at lower engine speeds, you'll beat the pins right out of the rollers.
If you're stuck on solid roller, I wouldn't blame you as they make great power and are very consistant, buy very good lifters. I've heard the Crowers last a long time. I'm sure others will chime in on what lifters live. The regular Comp ones don't like street use.
If you are under 6500 RPM, consider a hyd roller more seriously, they make great power and can live forever.
FWIW, I ran a Comp 252/256, .420 lobe solid roller in a 10.5:1 421 sbc with -10 heads. 2700 stall, 3.73, 28" Hoosiers, 3400# 77 Nova. Ran consistent 10.6's all day shifting at 5900 RPM. 9.8's on a 0.052" N2O jet.
I run that smaller cam (XR292R) in a 396SBC @ 11.5:1 compression. It's seen more than a few thousand miles and holds it's tight lash(.016/.018) very well with Comp ProMag rockers and poly locks. I do run an oil restrictor. Comp Tie Bar lifters, trend PR. I think you'll find more than .2 ET reduction. It will appreciate a higher stall. I think those cubes and that top end will be quite a bit better with .600" lift vs. .525". Pump gas, FR5 NGK plug..It should drive like a champ for ya. You will want a bronze gear for your distributor. Goodluck!
1 - 15 of 15 Posts
