What do you think about Eagle rods
2097 Views 2 Replies 3 Participants Last post by  Zeke1
I'm thinking about installing a set of eagle 3d rods in my turbo motor what do you think about the eagle products and upgrading the rod bolts to L-19 or is scat better!!!!!!!!!!!!!!!
1 - 3 of 3 Posts
aren't scat and eagle the same rod pretty much?
I've run the eagle and the Ohio witch is accually a scat rod sold under there name had no problem's with either on a sb making 750+ na and then squirt the crap out of it if that's all you budget allows so be it but don't think they are as good as a carrillo, oliver or other high end rod there not, that being said I now run oliver billet's and sleep much better :-D
1 - 3 of 3 Posts
