1 - 20 of 20 Posts
Pat Musi
Joe Lepone Jr.
Todd Hoerner
Ricky Smith
They're all running Accufab's "Mountain Motor" EFI Throttle Bodies.
These are the standard 2.75-inch bore units and are available with or without the optional upper fuel rails. Accufab also offers these units in 2.50-inch bores, 3.00-inch bores and 3.50-inch bores, with or without the upper injector system.
Call Sonny's Racing, Pat Musi Performance or Accufab for more info.
That's some sexy hardware.
got the mountain throttle bodies with the upper injection and 16 injectors but screwed without the tweeking from Hoerner. We did set the comp national record a couple weeks ago.
Discussion Starter #10
Whats the cfm of just one of those things?
Each standard (2.75-inch bore) 2-brl unit flows 1849 cfm @ 28-inches. A set of four is good for 7,396 cfm. The smaller ones (2 1/2-inch bores) flow 1328 cfm per unit.
The big units (3.0-inch and 3 1/2-inch) flow 2284 cfm and 2738 cfm per unit respectively.
Discussion Starter #12
There are more than one way to mount these 2-brl throttle bodies.
Sonny used them on a big inch street car engine, ginned up his own "progressive linkage". Just like the old days with four 2-brl Stomberg 97's ("4 duces"), only bigger. Of course, one of Sonny's 904-inch engines needs more air than a 239-inch flathead.
How could you set these up on a N/A SBF with a stick?
Discussion Starter #15
Here's another way to go. You can use a Dominator style 4500 carb and get 1050-1100 cfm...
...or, you can install an Accufab 8500 throttle body and get 3698 cfm.
The Holley Dominator 4500 weighs in at 13 1/2 pounds and measures 12 1/2" long x 7 3/4" wide x 3 3/4" tall. The Accufab 8500 weighs 3 1/2 pounds and measures 7" x 7" x 3" tall. The 8500 is basically dual 2-brl units merged together (same 2.75-inch throttle bores). And the linkage is included. The 5/8" thick adapter shown in the photo allows the Accufab 8500 to be mounted on any 4500 style intake manifold. Slight loss of cfm with the adapter.
Discussion Starter #16
What are the pros and cons of running the injectors in the throttle bodies?
An on-going debate. I'm not sure which is better. Sonny swears by injectors on the top and in the runner, Musi says it does not matter. Personally, I lean toward having the upper injectors if for no other reason than to cool the air in the plenum of the intake manifold.
Discussion Starter #19
I meant to post this photo earlier. This is the car that Joe Lepone Jr. is running now, and not his Camaro (I couldn't find a photo of the Mopar). Same huge Sonny's/Musi powerplant, same Accufab throttle bodies. I hung out with Joe this past weekend at the NMCA West event at Famoso.
I bet that was the highlight of your weekend. huh?? ROFLOL.
I was gonna say something about the picture of the Camaro, but its not that big a deal.
Bob
1 - 20 of 20 Posts
