1 - 10 of 10 Posts
ive been tossing around the idea of getting rid of my no name converters and trying something a little better on a budget.
i can get a 8 inch stage 2 tci with 100 runs for 250.00
i can also get a new fairbanks 8 inch for 300 was 600-700 new.
these are affordable to me.
ive been running ******* converters and find they have too much slippage . so i want to try something better.
i am running a 91 s10 short bed with 28 10.50 tires 350 turbo 4.10 gear and a mild 406 with motown 220 heads 10.1 to1 comp. matching motown intake (looks like super victor) 950 hp comp extreme energy solid with 252 260 @50 with 545 555 lift . then i installed 1.6 rockers to put me in the 585 595 range. running all msd ignition . i dont see ahy the phuck i can not get this thing to run good.
i went to track with powerglide and 4200 stall and ran a 11.67 @115.9 and a 168 60 foot. went thru traps at 6250 rpm.
i have changed to a th350 and im looking for a quality stall on a budget.
let me know your thoughts on engine combo and or stall combo.
i feel i need more converter . i am upgrading to a roller cam and more compression this winter unless she wakes up this fall.
thanks
If you can give the numbers on that TCI converter, I will try to help you with your combo. The stage 2 description doesn't tell me much. It will have TCI and then the part number right after that. It should start with the numbers "2540".
Tony Akins
Morace Motorsports
(251)-971-1556
Tough nut to crack there.
The torque converter is NOT the place to save money though, especially on a bracket ride.
It's tough to shell out $800 to $1000 for a doughnut, but it is better than having a $400 "bargain" converter take a dump before you get on the trailer and ruin your transmission, as well as throwing away the $400.
(been there, did that)
After all that, I had $1900 in my converter, if you add the damage and original wasted $400. Lesson learned.
If you can pick up a nice "core" unit cheap, and have it re-worked for your combo, you might save $300-$400 on the deal in the end.
being on a budget is rough, i personally would never run a used converter because you never know what can happen and 80% of the time you end up having to freshen it or restall it anyway. if you have a ******* converter you can take it to someone good and have it set up right, if it needs nothing for parts then itll usually run around 150$ or so which will fit your budget. on the high end it usually cost around 500$ to fix a toasted converter which is still cheap and you end up with a new unit. just my opinion though.
Discussion Starter · #7 ·
TODAY I SPOKE WITH TCI AND I THINK WITHOUT LOOKING THE TCI IS 250413 AND THEY TOLD ME IT SHOULD STALL AROUND 5800-6000 TOO MUCH FOR MY TASTE.
TODAY I BOUGHT THE FAIRBANKS AND I HAVE A STUPID QUESTION BUT IT IS SUPPOSE TO BE A 8 INCH BUT MEASURES EXTERNALLY 9 1/4.
NOW IS A CONVERTER MEASURED EXTERNALLY OR IT'S INTERNALS.
THIS WINTER THE ENGINE WILL SEE 11 TO 1 COMP WITH A NICE ROLLER CAM
I JUST CAN'T SEAM TO MAKE THAT 10 SEC CLUB.
THANKS FOR THE ADVISE​
I have a Dayco that wouldnt be my recommendation to anyone with a big budget, but it has lasted for quite a while now. It was only $250 or somewhere in that range.
What was the stall on the Fairbanks?
Where do you plan on shifting the engine at? With your combo, how much horsepower do you think you have. I don't think that TCI converter will stall that high. That converter would be closer than you think.
Tony Akins
Morace Motorsports
(251)-971-1556
1 - 10 of 10 Posts
