1 - 6 of 6 Posts
I was wondering what is the ideal compression for a 351 turbo motor with convential style trick flow heads!
im in the process of building a 351w with 9:1 comp. with trick flow 190 fast as cast 64cc heads and dss racing pistons. so 9:1 for street and moderate boost of 8.5:1 with more boost
can you get away with 11.0 compression or would it just be stupied to try! and it would be on e85 if that would help
check out e85performance.net ive considered e85 even at 9:1 but ive heard mixed thoughts and i only know of 2 e85 pumps near me.
11 would probably be a bit much. Now if you could get that to 10.... It would be about right.
1 - 6 of 6 Posts
