1 - 7 of 7 Posts
I have Wilwood brakes and I need to replace them and need to know what compound to use.The stang wieghes 2700 with me in it and has gone 139 in the 1/4 and should go 150 or so once I use the bottle.Thanks for the help
Is that for the 4 piston Dynalite calipers ?
Yes. Here is an application listing for those pads. They fit several brands.
http://www.summitracing.com/parts/HWK-HB100J-480/Application/?prefilter=0
In addition to those, they will also fit Strange calipers with a minor mod. The Strange use a bridge bolt across the top to hold the pads in the caliper. Wilwood uses a cotter pin. If you drill the top center hole out from cotter pin to bridge bolt size they will fit the Strange calipers as well.
I've tried many different ones, but these are the best. Easy on the rotors and stop fantastic.
Hawk in the DR97 drag racing compound.
HB100J.480 is the part # for Wilwood 4 piston calipers.
The "J" denotes the DR97 compound
Thank You, Thank You, Thank You
I just got a set of these pads and MAN what a difference.
My car is rear brake only and it got interesting after I got to the 140 mark with the stock pads.
Now the pedal responce is 100% better and it stops great.
Thanks Again
1 - 7 of 7 Posts
